BRAND SPANKING NEW IN OEM PACKAGING
Tomei Cams/Spec B Valve Spring Retainers and Solid Lightweight Lifters
Cams intake 290deg exhaust 252 deg Tomei PROCAM
Spec B Valve Springs and Retainers ~ 11.5mm MAX lift
and Solid lightweight lifters....
Its sitting here doing nothing and i want to get rid of it...
im asking for the whole lot now $1600 at this price im practically giving it away...
PM if your interested, if you dont intend to buy please don't waste my time
Update
Items are now SOLD thanks for the interest
]']this include cams as well?
for what car?
32,33? or 34?
yes the cams are included... the exhaust cam is only compatible with the R34 RB26DETT but the 290deg Intake can be used on any RB26DETT you could sell the cam on its own, they retail for $600 ex gst on their own...
Heres some more information
The Exhaust CAM is designed for R34 RB26DETT however the Intake cam 290deg 11.5mm lift + valve springs and lifters will work on all RB26DETT motors. BTW These are Tomei PROCAM series not PONCAM's they require the use of upgraded springs
The R34 RB25DETT Exhaust cam is designed differently, it appears for the R34 the Exhaust cam is only avaliable in 252deg and 260deg configuration...
The retail price of each part is as follows:
Tomei Solid Valve Lifters $607.20 ex GST
Tomei B Spec Springs and Retainers $902.70 ex GST
Tomei 290deg 11.5mm lift Intake PROCAM $633.30 ex GST
Tomei 252deg 9.15mm lift R34 Exhaust PROCAM $640.30 ex GST
Total Price of $2783.50 ex GST
$3061 inc GST
(Price from HiOctane Racing)
I dont think anyone would sell what i have for the price i have now, so ppl that who are offering ridiculous prices for an already cheap package :bs!:
Look. Im not here to try and force you to sell the above mentioned items serperately. However, if you dont find someone to buy the whole set... PM me and i will purchase everything less the cams. I offered you a price and by the looks of it it was way out. So give me a ball park figure to work from and we will take it from there. (Thats if you change your mind about seperating ofcourse)
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
