Would any of you guys be interested in coming to my wedding.
I've been after a R30, R31, R32, R33, R34 skylines for a while now. Just want to have as many skylines as i can get to take a few people to my wedding.
The wedding is on the Saturday 27th August....Any takers???
I can organise for you to stay with someone from PULSE Motorsports for the weekend, and maybe even feed ya at the reception.....
The only condition is your car HAS to be very clean in and out :rofl:
reply on here or to me at [email protected]
Thanks
  • Replies 47
thanks guys should be up there at the end of the yr. Is there any1 good to tune apexi power fc or should i get it tuned be4 i come? cheers jamie
Either way would work, Get it tunned while your down thier, Depends on your mods.
Or chase down on of the cars with Prospool Stickers on them and they will be able to help you out.
They aren't hard to find there seems to be every skyline in Cairns with ProSpool on it.
BTW congrats to Nat55 with a 407.10 dyno run on Saturday
Still far off its potential power output yet. But as you mentioned not bad for 17psi.
You should see better results at the next car show in October (from memory).
the scene is dud up here on the tablelands. couple of 33's one 32 and i've got the only 34 so far. tonnes of comonwhores and falcoons . i might be interested Packy if i have got the time . i've got a white 34 gt-t not too bad condition had it in the mareeba street percession last week come ,up and see me one day.
Yes thier were around 7 - 8 cars from cairns down at the street meet on the 2nd of this month.
Yeah I thougt so. I was there for a bit and I did like the RB20 powered s13 there.
Something you dont see everyday. Well in Townsville anyway.
kewl, i've got to come up to cairns soon, to meet a few people. And to give my 33 a good run on the highway.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
