Would any of you guys be interested in coming to my wedding.
I've been after a R30, R31, R32, R33, R34 skylines for a while now. Just want to have as many skylines as i can get to take a few people to my wedding.
The wedding is on the Saturday 27th August....Any takers???
I can organise for you to stay with someone from PULSE Motorsports for the weekend, and maybe even feed ya at the reception.....
The only condition is your car HAS to be very clean in and out :rofl:
reply on here or to me at [email protected]
Thanks
  • Replies 47
thanks guys should be up there at the end of the yr. Is there any1 good to tune apexi power fc or should i get it tuned be4 i come? cheers jamie
Either way would work, Get it tunned while your down thier, Depends on your mods.
Or chase down on of the cars with Prospool Stickers on them and they will be able to help you out.
They aren't hard to find there seems to be every skyline in Cairns with ProSpool on it.
BTW congrats to Nat55 with a 407.10 dyno run on Saturday
Still far off its potential power output yet. But as you mentioned not bad for 17psi.
You should see better results at the next car show in October (from memory).
the scene is dud up here on the tablelands. couple of 33's one 32 and i've got the only 34 so far. tonnes of comonwhores and falcoons . i might be interested Packy if i have got the time . i've got a white 34 gt-t not too bad condition had it in the mareeba street percession last week come ,up and see me one day.
Yes thier were around 7 - 8 cars from cairns down at the street meet on the 2nd of this month.
Yeah I thougt so. I was there for a bit and I did like the RB20 powered s13 there.
Something you dont see everyday. Well in Townsville anyway.
kewl, i've got to come up to cairns soon, to meet a few people. And to give my 33 a good run on the highway.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
