hi:
I had a set kei office sell. It suit R33
They are height and soft/hard adjustable.
There was no spanner provided .
The coilover with exc-condition. No leakage.
only want HKD5700 including UPS speed postage.
I sell it because i got the worng one for my R33 4WD.
PS: It was a "eye" one at the rear. Please check before take it!!!
regards
https://www.sau.com.au/forums/topic/74462-fs-kei-office-coilover/
yeh a price would be good.
He has stated the price: "only want HKD5700 including UPS speed postage". Does anyone know how to convert Hong Kong currency to Aus. dollars?
Had these on my car for 2yrs, VERY hard (on the softest setting), but would be great for drifting, as that is what they are designed for.
  • 1 month later...
hey mate, im keen for these... reckon you could hold on to them for a little longer?? like a few more weeks?? how would i go about paying for them??
cheers
Linton
Hello,
Pls bank the money to my account. Give me your postal address. Once I receive the payment from you, I will post the stuff and give you the reference number for the parcel! THX!
Regards,
Sato
cheers
Linton
Edited by sato
Hi Linton,
Pls give me your personal e-mail address! and I will send you the bank details for the payment!
also your address so that I can post you the stuff once I have got the payment! THX!
CHeers,
Sato
cheers
Linton
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
