Hi all,
We have another special offer running at the moment on Trust V-SPL Intercooler Kits for Skyline GTS-T.
Available to suit:
* Skyline R32 GTS-T - (HCR32)
* Skyline R33 GTS-T - (ECR33)
* Skyline R34 GTT - (ER34)
These kits are complete bolt on packages and include the intercooler, piping, hoses and clamps
Quality kits at a very competitive price! - Australia wide delivery available.
We can also supply virtually anything from the Trust catalouge
Enquiries can be emailed to [email protected]
thanks
This special is on Trust V-SPL kits only - The intercooler is not available seperately though we have other universal type intercoolers available if required.
If you have a query about products other than the Trust V-SPL kit then please email us rather than discussing here.
Thnks
600 x 300 x 75mm
Any modification (removing of battery, AFM or anything else ) required with the piping kit, and is it a 2, 2.5 or 3" piping kit that is supplied for the R32 gts-t???
The kits for GTS-T only require a hole to be cut in the gaurd under the battery tray for the piping to run through.
The piping is 2.5 inch
Thnks
The price of $1199 is for the intercooler kit only and does not include fitting. This is an excellent price as anyone who has looked around will know.
We can arrange fitting at an additional cost of only $180
All round the prices we are offering are too good to miss and the offer is limited so please confirm your orders asap to avoid missing out.
All pm's and emails have been replied too.
Thnks
  • 1 month later...
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
