I'm running HKS 1000cc Injectors......too big?
I understand that larger injectors are not as efficienct, or should I say control over say smaller ones.
Still couldn't my AFR be improved for highway use say on light loads or maybe a closed loop operation or how about a whole new map that I can just zap in using a laptop. When I want it back to normal I can just re-zap it.
Am I just chasing my tail or should I just put up and shut up and be happy with everything.......who dosen't want to have everything! :headspin:
  • Replies 46
Larger injectors have trouble atomizing the fuel well with small duty cycles.
The larger injectors *nismo and I also thought hks* 'generally' have multiple sprays.
For example they may be a twin spray.
That was my understanding, I could be wrong. ;)
I'm guessing that for fuel to atomise better, the finer the spray or should I say the finer the mist of spray, it will atomise better.
Fuel pressure would not have anything to do with this aspect, I think.
So in larger injectors they can have multiple sprays to makeup for the effiency.
I just checked mine and they are single spray units..... If I change them to something with multiple spray units, then do you thing I might get better effiency?
Thanks MsG_ChRiS... don't I sound the winger!
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
