Ok, if anyone out there is running standard position low mount turbos with a MAP sensor equipped ECU (no air flow meters), ive got some stainless piping to suit. I had this custom made, but decided to go a single turbo set up. Air goes through a pod style filter mounted in the gaurd, through a 3 inch 'Y' piece and into the two turbos. All the rest of the piping is there too. Ill try to get some pics, but its all polished and looks nice. After $250 for it. Considering what it cost me to get it made, this is cheap if it suits your application.
Shaun.
0414972596
https://www.sau.com.au/forums/topic/74835-rb26-stainless-induction-piping-fs/
Pics added. Sorry about the quality; theyre photos of photos. Its also hard to see the 'Y' piece; its hidden away in these photos. Note how the filter is in the gaurd. Its all pretty compact and works really well. It doesnt come with the standard TWIN TURBO piece, its already sold.
Shaun
0414972596.
Shaun, could this be provided with the piping to fit to the twin turbo pipe? I have one already but want the fittings from the turbos to TT pipe and the turbo feed pipe as shown here.
Yeah Geoff, all the piping fits the standard twin turbo pipe in the standard position. Theres peices from the two turbos as well. Is this what you mean?
Shaun
0414972596
Yeah I have the TT's off a GTR34 and the "twin turbo" top pipe but fabricated the rest myself. I just want something a bit nicer. So what I'm after is the visible Y pipe that goes to the turbo inlets, as well as the pipes that go to the "twin turbo" pipe from the turbos.
TT pipe looks good polished, must do that. :D
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
