  • Replies 58
The 1070 hp figure was done during tuning by Sub Zero and is real but the Autosalon dyno only went up to 200kph  :chairshot
Plus the fact that the gearbox blew up didnt leave much room for improvement.
That's all the dyno graph posted goes to... I fail to see your point... :confused:
630Kw != 1070HP
P.S. Nothing wrong with nitrous IMHO... :)
I should have been more clear sorry
The hp read of 1070 was made at Sub Zero on their dyno.
Not at the Autosaslon dyno.
If he had of scored 1070 on Saturday they would have smashed the record.
The dyno at autosalon only read up until 200kph.
thats why the cars with power glides got really bad hp scores.
Nothing wrong with nos just pointing out the fact that Sub Zero will Put nos on anything.
At that sort of power what could possibly be put on the car for 1500 more dollars?
Not easy power just more :rofl:
No one said with a $1500 budget there is anything else that would add “more power”. The point was, people are using the nitrous kits as easy power.
Each to their own I spose.
nos is good but i think for dyno roller comps they should just use the engine power produced and have a totally different section for the nos cars. then it would be easier to judge the cars on there actually horse power not just bolt on a nos bottle for extra kw/hp
I disagree as adding nitrous is EXACTLY the same as bolting on a bigger turbo.
When someone bolts on a bigger turbo, do you stand there and say "yeah but lets see what the engine produces with a turbo half it's size or let's take the turbo off completely and just see what the engine does without any boost". I would think not. Using nitrous is effectively only adding more oxygen to the process and there is a fine art to setting it up correctly. If someone wants to run nitrous, fine....they will pay the price for cheap horsepower if they have not set both it and the engine up properly. It takes skill and a very tough engine to run it safely at high levels as nitrous has nearly 2.5 times the air content of normal air which increases the risk of detonation and engine failure. Just think of it as adding another turbo for 10 seconds.
couldnt have said it better myself
good point. but u cant run nos on the street but u can run a bigger turbo. i wasnt uping any1, i just reckon they should have 2 different areas in the roller comps. maybe im wrong but it would give a more true indication of what people are goin to see in a car driving on the street or at the strip. just my 2c.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
