It's on again boyz and girlz. Bigger, Better and cheaper!!! Dyno day/Shootout on the 16th of July at Berowra (10 mins from Hornsby) Bookings are a must, details are as follows:
Where: Dumar Auto Technics, 12 Berowra Waters Rd, Berowra
When: Starts at 9am, Saturday 16th July 2005
Cost: $50 per car with certified Dyno printout and trophies
Classes Are:
8 Cyl
6 Cyl
4 Cyl
Rotary
For additional info and bookings please call Chad on 0422 140 919 or 0433 405 788. You can also PM me and reply here......
Had a great turn out last time so hoping for the same again.
https://www.sau.com.au/forums/topic/75187-boost-bitz-dyno-day-ii-july-9th-2005/
Sorry everyone but site is under construction and for all of those who don't know me, I am a turbo and performance parts specialist. Please Pm me your Rego, name and number to reserve a spot for the day.
Pm sent ApleX.
