Thanks for the offer mate I'll get back to you. During event logistic are in the back of my mind but I haven't given any thought to them yet as to busy with the car.
No worries champ, you got my number and email so hit me up if you need a hand with anything ;)
https://www.sau.com.au/forums/topic/75257-rallye-burnie/#findComment-1383409
t01-100: what do you know about the bluebird Jason White is taking in the Fulllock drift day?? im a bit of a bluebird fan and was curious as to what he may be using to power it and his suspension setup
NIssan powered, with aftermarket suspension with lots of camber. :Pimp2:
https://www.sau.com.au/forums/topic/75257-rallye-burnie/#findComment-1387541
wow, ive seen a few done like that and it isn't an easy task... no doubt he will make easy work of it
Well knowing Jase he will make it look like its stock and still have time to hide all the extra goodies.
Should be good to watch :jump:
https://www.sau.com.au/forums/topic/75257-rallye-burnie/#findComment-1391389
griffo is running the dirty old rx7, i give it two runs before the engine looses a rotor!
BWAHAHAHAHAHAHA im sure it will hold up.
At least there are a couple of locals willing to go in and turn it on for us to have a laugh for the weekend :Pimp2:
https://www.sau.com.au/forums/topic/75257-rallye-burnie/#findComment-1392873
I have entered Rallye Burnie.
Anyone here going for a look?
Warning Benno, you are infringing copyright of 26 Motorsport by posting pictures of the Green Eyed Monster. You were contracted by us to drive 4 rounds after I broke my neck whilst leading Targa if you had forgotten and there was no clause included for any future self promotion of yourself in a car you don't own.
Please remove these pics asap or transfer them to the Octagon Series website where they belong.
Signed
THE BOSS of BASKERVILLE!!
https://www.sau.com.au/forums/topic/75257-rallye-burnie/#findComment-1418808
26motorsport is talking about the pics in my gallery.
26motorsport owns the R32 GTSt that I raced in the pics.
Car looked mean with the green :Pimp2:
Hey Stuart is it just me or does the car seem to go better when your behind the wheel???
BOSS OF BASKY, Mark??? :matrix:
Congrats ont he title Mark, was good to watch a Liner tear it up against the rest of the rubbish that was out there on the track (must of been embarrassing for them really to go up against such a fine/prestige motor vehicle) :uh-huh:
https://www.sau.com.au/forums/topic/75257-rallye-burnie/#findComment-1419661
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
