Thanks for the offer mate I'll get back to you. During event logistic are in the back of my mind but I haven't given any thought to them yet as to busy with the car.
No worries champ, you got my number and email so hit me up if you need a hand with anything ;)
https://www.sau.com.au/forums/topic/75257-rallye-burnie/#findComment-1383409
t01-100: what do you know about the bluebird Jason White is taking in the Fulllock drift day?? im a bit of a bluebird fan and was curious as to what he may be using to power it and his suspension setup
NIssan powered, with aftermarket suspension with lots of camber. :Pimp2:
https://www.sau.com.au/forums/topic/75257-rallye-burnie/#findComment-1387541
wow, ive seen a few done like that and it isn't an easy task... no doubt he will make easy work of it
Well knowing Jase he will make it look like its stock and still have time to hide all the extra goodies.
Should be good to watch :jump:
https://www.sau.com.au/forums/topic/75257-rallye-burnie/#findComment-1391389
griffo is running the dirty old rx7, i give it two runs before the engine looses a rotor!
BWAHAHAHAHAHAHA im sure it will hold up.
At least there are a couple of locals willing to go in and turn it on for us to have a laugh for the weekend :Pimp2:
https://www.sau.com.au/forums/topic/75257-rallye-burnie/#findComment-1392873
I have entered Rallye Burnie.
Anyone here going for a look?
Warning Benno, you are infringing copyright of 26 Motorsport by posting pictures of the Green Eyed Monster. You were contracted by us to drive 4 rounds after I broke my neck whilst leading Targa if you had forgotten and there was no clause included for any future self promotion of yourself in a car you don't own.
Please remove these pics asap or transfer them to the Octagon Series website where they belong.
Signed
THE BOSS of BASKERVILLE!!
https://www.sau.com.au/forums/topic/75257-rallye-burnie/#findComment-1418808
26motorsport is talking about the pics in my gallery.
26motorsport owns the R32 GTSt that I raced in the pics.
Car looked mean with the green :Pimp2:
Hey Stuart is it just me or does the car seem to go better when your behind the wheel???
BOSS OF BASKY, Mark??? :matrix:
Congrats ont he title Mark, was good to watch a Liner tear it up against the rest of the rubbish that was out there on the track (must of been embarrassing for them really to go up against such a fine/prestige motor vehicle) :uh-huh:
https://www.sau.com.au/forums/topic/75257-rallye-burnie/#findComment-1419661
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
