i have these coilovers for sale. these are new and asking 1350 for them. they are suited for r32s. these are height and dampers adjustables and come with the tools to adjust them.
im selling these coz im in debt and if i dont pay off my debt soon, im gonna be in alot of trouble. anyways dont want to get into my personal life.
pm for pics or have any questions.
https://www.sau.com.au/forums/topic/75870-fs-hks-hipermax-coilovers-new/
  • 3 weeks later...
