I have heard APC are good but they charge like a wounded bull, ie if you have plenty of money go there but if your on a tight budget might be best going elsewhere. They charge similairly to croydon racing development.
Depends on what type of service/work your after. Different people prefer different companies.
I prefer to use Gavin Woods - Autotech (www.autech.net.au) as I have done for the past 3 years.
Mercury Motorsport are getting up there with a highly regarded workshop which is always full of performance cars.
Just depends on your personal preference of company.
