Mate...
I'm in need of some slicks for my R33 GTS-t...
I read in Zoom that you ran 15x8.5" slicks on the back of your car? Did you fit those over the standard rear brakes? If so, could you please hook me up with some details on where I can get some of those "Convo Pro" rims?
Cheers mate,
Andrew.
https://www.sau.com.au/forums/topic/7667-attn-try09s/
Thanks heaps Brett!
A few more questions.
I'm deciding whether to use 26.0/8.5-15 or 28.0/9.0-15 MT ET Drags...
I have a manual gearbox, so I guess I'm going to try and minimize the shock on my drivetrain as much as possible... Would the larger diameter 28s be a lot harder to spin up, and hence place a larger shock on my gearset?
I'm assuming that it's easier to spin a smaller diameter tyre than it is a larger one? I'd love the softer sidewall of the 28s, but the increased drivetrain shock may not be worth it?
Secondly, I've decided to go with the Cragar Drag Star II /Weld Pro Star style rim... There are a few different options available, but I'm not sure how they translate into offsets and stuff...
Which one would be suitable for the rear of the GTS-t?
15 in. x 8 in. (5 x 4-1/2 in. B.C), 3-1/2 in. RS
15 in. x 8 in. (5 x 4-1/2 in. B.C), 43-1/2 in. RS
15 in. x 8 in. (5 x 4-3/4 in. B.C), 3-1/2 in. RS
15 in. x 8 in. (5 x 4-3/4 in. B.C), 4-1/2 in. RS
15 in. x 8 in. (5 x 4-3/4 in. B.C), 5-1/2 in. RS
Thanks again mate :mad:
https://www.sau.com.au/forums/topic/7667-attn-try09s/#findComment-112626
Hi merli firstly you will not fit the 28s because they will expand too much and hit the guards and you won't fit the 26x10s unless you fit solid bars instead of suspension as it was our first run with the 26x10s cought the side skirts and ripped them off and put a big dent in the tyres so i suggest the 26x8.5s i have run a handfull of 9sec passes at over 140mph on that size with a standard diff, drive & tail shaft as for the gearbox i cant help you there other than it's cheaper to replace a cluch than a gearbox so just flair the cluch a bit, as for the wheels i dont know off hand what the offset is but i do remember it was the most furtherists offset out that centre line do on the convos ring shane if you get stuck, hope this is of help.
brett.
https://www.sau.com.au/forums/topic/7667-attn-try09s/#findComment-112672
Excellent... I guess I'll go ahead and order 26x8.5-15s then!
You ran your passes on standard diff, driveshafts and tailshafts?!? I've already broken one driveshaft on my first outing! And that was just on 18" Dunlop Formula Rs! I was expecting to snap a whole bucketload when I put slicks on... Hmmm... I guess it's good news to hear yours have held up, hopefully the new one will suffice...
I'll give Shane a call and see if he can shed some light on those weird Imperial measurements for me :mad:
Thanks for all your help mate!
Andrew.
https://www.sau.com.au/forums/topic/7667-attn-try09s/#findComment-112710
    • I left that life behind me. After so many rod bearings... (Had quite a few M3s)
    • Both Coils and Loom are OEM from the dealer.  I have not tried the Chinesium AFM. I Might today. Will get a timing gun to check this, to be honest I been meaning to check the timing because everything timing related is as the car came from Japan, being set by whatever shop did the timing 1.5k miles ago. I believe it is running rich all the time actually, as the pops and bangs feels like unburnt mixture in the exhaust. But I will check the pump and regulator. PS also new OEM fuel filter is in during the maintenance before these slew of misfires started. Cas been placed on the same position as it was before removed, same markings that were left by the shop that did the timing before I bought and imported the car. Thank you all for the responses so far by the way. Seems like I need to pay more attention to CAS condition and timing. Will check on that and report back here.
    • Buyer beware. Assume everyone is dodgy on the internet unless proven otherwise.
    • Try unplugging the smaller plug from the controller under the parcel shelf. right side when standing at the boot (HICAS controller). It's sort of saved me from the car killing me (HICAS spazzing out),
    • Been looking at the MK60 too but looking at a few options for my shitbox
