i'm just wondering how much if at all it will lower my car. i was looking at the pic that prank posted, my car's height is the same as his, my car even has the same 18" DTM wheels on it.
i'm not expecting the springs to dump the car to the ground but I am after a bit of a dump. is this going to happen?
