GENUINE Pivot Volt Stabilizer
comes with 5 lengths of earthing cables
·Improved audio quality.
·Increased torque and response and power.
·Stabilized idling and improved engine kick over.
·Increased headlight brightness.
·Improved fuel economy.
·Improved battery life.
GENUINE (LEFT) >>>>>>>>>>>>>>>>>>>>>>>>>>>>> FAKE (RIGHT)
Main Unit = $90.00
Full kits with 5 cables = $120.00
Advantages/More information at: http://bt-revolution.com/RAIZIN.htm
Edited by BT-Revolution
  • 1 month later...
  • 4 weeks later...
Full kits and main unit are in stock
Buy genuine Pivot products!
Becareful fake units which could cause a damage on your car.
Recently, we've got an email from someone who purchased a copied unit informing that a fake unit interfered the alarm system
Genuine PIVOT will have a PIVOT Logo on the main unit as shown on the picture below. Genuine PIVOT products are made in JAPAN ONLY
Care to forward that email to me at [email protected]
Just got off the phone to my installer and can't see how a volt stabilizer kit can have any affect on an alarm system :(
To my knowledge I am the only one in Australia selling Raizin Volt stabilizer kits and I have not heard of any faults. In fact we have reviews and haven't had any problems, all great results. Why would a customer that purchased a non Pivot item email you?
Greg
Sorry, this might just be me but people may be more interested in buying these from you if you advertised the selling points etc rather than continuously going on about non-pivot or taiwanese products.
Nath
Yes they look identical from outside,
just like Pivot super baby timer that has been copied even the packaging but internal is not the same.
"Raizin" is a model/trading name of this product, Not a brand
Genuine Pivot will come from Japan only. We just provide an information to buyers to make sure they know the difference.
Genuine PIVOT will have a logo stamps on.
$120.00 for genuine full kits now
  • 2 months later...
i think what the people are asking are for differences in performance rather than aesthetics.
Exactly ! If you can prove that the Pivot version works "better" than the non-Pivot version OR prove an inherent fault or product deficiency with the non-Pivot units, I'm sure people will buy the Pivot ones. :P
Having poorer quality internal parts, we would assume like with any fake electronic parts that you would get less usage life, less efficiency to volt stabilisation, etc.
For example, FAKE pivot turbo timers don't work properly and become faulty after a short time.
Even look at fake Apexi Turbo timers on the market.
http://www.apexi-usa.com/news_special.asp
It is buyers choice to risk buying inferior products. We are only giving awareness.
  • 4 months later...
A few left in Stock.. and more coming!
Stick with Genuine Products!!
FAKE:
http://www.pivotjp.com/imitation/imitation-raizin-e.html
Also available to order:
(Pivot Raizin Kits that have yet to be copied by china companies!)
Pivot Raizin SPARK
http://www.pivotjp.com/product/se/raizin-s-e.html
Pivot Raizin SOUND
http://www.pivotjp.com/sound/flame-vs-e.html
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
