i've posted this on another thread: is it just me or do i get better mileage from normal premium as opposed to ultimate?? im 99.9 percent sure i have a stock ecu ... have hi flow air filter ... decent aftermarket exhaust ... i get 300-350 on ultimate and 400-450 on normal premuim ... why is that?? .. and my cars an automatic ... r33 gtst.?? i've even tried normal unleaded ... but i think i would get about 300kms per tank cause i didn't fill up all the way, just seeing what the performance was. anyone got any ideas?? i'll just stick to normal permium now cause it comes out cheaper both ways. i've even tried woolworths premium and it gives me about the same mileage :D but i still think that normal premium (BP that is) gives me a better idle .. but i think i can feel more power with the ultimate.
thanks
https://www.sau.com.au/forums/topic/7805-weird-feul-economy/
Hmm, perhaps look at the most important factor when achieving fuel economy - how you drive the car. It all depends on how quickly you accelerate and deccelerate. Spend alot of time stop/starting (especially in an auto) and you will chew the juice, also time spent on boost tends to make a huge difference.
I only use ultimate, although I have tried premium. The main difference I noticed was a definate increase in responsiveness on ultimate - the fuel economy didn't change a heap - what does effect economy most is when I get friendly with the loud pedal.
https://www.sau.com.au/forums/topic/7805-weird-feul-economy/#findComment-114094
I think the main thing you should be trying to do if you are comparing fuels is drive them the same way, in similar conditions, ie road and weather conditions, and it may be a bit hard if you are just comparing with one tank only. Another thing to consider is that imports' ecu is tuned for 100ron fuel, the closer you can get to that the better is should drive.
EDIT: that is if you are driving an import, also try doing an ecu reset each time you change fuel
https://www.sau.com.au/forums/topic/7805-weird-feul-economy/#findComment-114333
i drive it harder when i'm using the normal premium ... i try to drive really conservatively when using bp98 cause i don't really wanna waste it ... but for some reason i get shitty economy ... i've tried many tanks of both premium and ultimate and i've resetted the ecus but still get the same results ... i wonder if anyone else has similar results to mine ... a friend with an mx6 turbo says he has similar experience in that he gets same if not better econmy ... i'm starting to think this bp ultimate isn't at all what its cracked up to be ...
https://www.sau.com.au/forums/topic/7805-weird-feul-economy/#findComment-114425
Castrol Vortex (96 RON) = 350-380km / 60L
Shell Optimax (98 RON) = 375-415km / 60L
I think its coz im more conscious of how little km's im getting out of the tank so slow down alot on the 2nd half to try and squeeze more km's out of it and get me thru a week atleast.
I've been doing abit more freeway driving lately and while having my A/C on 20c im about to crack 500km (Current record is 414km)which im really happy about because i know i could easily get 550km if i drove it like a normal person rather then giving it a squeeze on every single outing.
https://www.sau.com.au/forums/topic/7805-weird-feul-economy/#findComment-114804
Ultimate is approx 8c deerer than ULP, and if you aren't taking this into account you could be out by approx 50 or so km's worth on a full tank
Then the additional could be perhaps because your right foot is enjoying the additional power from the extra RON too much!!! :mad:
https://www.sau.com.au/forums/topic/7805-weird-feul-economy/#findComment-114882
the max i got from a full tank is about 480 from normal premium ... max from ultimate is about 370 ... and its not because i drive it really hard ... i don't .. i drive nice and slow ... why dont' people beleive me?? :mad: anyways i'm up for a service soon so i will see how my feul economy changes after that ...
https://www.sau.com.au/forums/topic/7805-weird-feul-economy/#findComment-114964
Yup now and then when i feel im getting good economy and i try and see how many km's i can get from a tank the most i have ever stretched it is about 60L (determined by the amount of fuel before it clicks when i fill up again).
What i'd do to get a digital read out of - fuel consumption, range and L's remaining like my dads Vectra... geeze it'd be good.
https://www.sau.com.au/forums/topic/7805-weird-feul-economy/#findComment-114988
I haven't had my R33 that long (so I guess I'm kinda still driving it hard!) but I get about 320kms out of 50 ltrs around town and my best so far was 450kms on a highway run (just locked on at 120km/h no hard accelarating). This is on Optimax. I have been putting Wynns racing formula occtane boost in every forth tank. Do these fiqures sound like I have a problem or are they pretty ordinary?
My last car a 2001 Astra I got 550kms around town and my best was 800kms on a trip to Melbourne!
https://www.sau.com.au/forums/topic/7805-weird-feul-economy/#findComment-121997
pfc got nothing to do with it.
if its tuned right you should get the extra power and better fuel economy than stock.
franks i'm guessing your in sydney or melbourne. most of u guys seem to get shitty fuel economy i really think the fuel has alot to do with it.
https://www.sau.com.au/forums/topic/7805-weird-feul-economy/#findComment-123211
If i just drive to work and cruise around my town i'll get 370km from 60L's
If i visit some women 30mins north afew times a week i'll get 400-425km from 60L's.
It just depends on what roads i drive on because i only have 1 style and thats 'go hard or go home'.
:burnout:
https://www.sau.com.au/forums/topic/7805-weird-feul-economy/#findComment-123442
More likely has something to do with the fact that the car was idling and wasting fuel more than it would in any other place i reckon
https://www.sau.com.au/forums/topic/7805-weird-feul-economy/#findComment-124512
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
