Hey just been shopping around for a turbo back system for my 96 R33. Just wondering what place(s) you would recommend to get this done or should i just go for the best price. So far the best quote is $1160 from Hyper Drive in Malaga for a 3" mild steel system inc. 3" dump, high flow cat and stainless muff. And thats with a dyno run before and after. Sounds pretty good to me, will prolly get this done soon. Any tips?
https://www.sau.com.au/forums/topic/78201-r33-exhaust/
I ended up getting an Xforce mild steel turbo back exaust. Dump/front pipe , high flow cat, stainless steel muffler.
$700 from Speedworks, supply only. Fitted it myself. Comes with bolts, gaskets etc.
Excellent for the price. Good gains, nice sound... too loud.
:thumbsup:
https://www.sau.com.au/forums/topic/78201-r33-exhaust/#findComment-1428571
thats a good price dude. was at speedworks today, same system u quoted with xforce bits was $960 on special. 1100 fitted. Unfortunatley i dont have the resources to fit it myself. I dont want it too loud though, My last car, a celica, had a stupidly loud system. Just gets annoying after a while, but at least the skyline will have some go, and not just show =)
https://www.sau.com.au/forums/topic/78201-r33-exhaust/#findComment-1428598
I recommend hyperdrive 100%. I got my 3" Stainless Xforce system from cat back + stainless cat for about $850 fitted. Round the same as you got quoted cos i didnt get dyno runs etc.. (+ i didnt need front pipe which is worth a couple of hundred).
Am very happy with hyperdrive and very happy also with Xforce.
https://www.sau.com.au/forums/topic/78201-r33-exhaust/#findComment-1428846
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
