I (and many other SAUers) own and recommend Bilstein shocks.
www.bilstein.com.au
You could also go for other well-known brands like HKS, TEIN and Cusco.
Note with any overseas made shocks, you should pair them with Aussie springs (like King Springs) to suit our crap quality roads.
https://www.sau.com.au/forums/topic/78233-shockies/#findComment-1428820
www.bilstein.com.au
So with the bilstein do they come adjustable, i have adjustable tanabe at the front
and need the rear to be replaced
cheers
https://www.sau.com.au/forums/topic/78233-shockies/#findComment-1428827
In the interest of balance, koni's are every bit as good as bilsteins:
http://www.toperformance.com.au/index2.html
I've used both, road and race, car and motorcycle. Properly set up they are equal. Personally I'd recommend looking at Bilstein's or Koni's over the 'name brand' Japanese suspension.
https://www.sau.com.au/forums/topic/78233-shockies/#findComment-1430893
Sorry SteveL, but they are not. I use Konis on lots of cars, I like them very much. But not on Skylines, since they are not sold in Europe, Koni use Japanese recommended valving. This simply does not work as well as the Bilstein valving in our conditions. I am not the only one with this opinion, check around the guys that have tried both.
https://www.sau.com.au/forums/topic/78233-shockies/#findComment-1431174
You assume that I haven't....I've found that in virtually every case there's been other explanations (eg poor spring choice). Indeed I've found the same with Bilsteins. As I said.....'properly set up......'.
https://www.sau.com.au/forums/topic/78233-shockies/#findComment-1431195
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
