Gday guys, I have a problem here, possibly more than what i first thought. This is the problem. In the mornings, the car will start fine, and run fine. But, after a while, once its warmed up etc.. it will start dropping cylinders. as if the fuel is not being burnt? i have checked the plugs, they are fine. I have checked the coilpacks, and the resistance seemed to come in at the correct ohms. But, it just seems to not want to work.. So thats why i ask what would be the symptoms of a cracked block? maybe its leaking water into the block causing non explosing? any ideas people?
Thanks for your help.
https://www.sau.com.au/forums/topic/81163-cracked-head/
Coil packs for sure.
Unplug each one whilst its running warm. When you find the pack that makes no difference to the way its running, you've found the dud.
If it were head/head gasket there would be steam out of the exhaust and oil in coolant/coolant in oil
I bet its the coil packs, one or more is stuffed its a common R32 problem.
https://www.sau.com.au/forums/topic/81163-cracked-head/#findComment-1474934
Ok, i will take a look at that, see what happens... so im assuming you mean, pull the plug of, and on again. Im pretty sure thats what your refering to. i will take a look at that. If it was pumping steam out the back end, would it be a white colour?
https://www.sau.com.au/forums/topic/81163-cracked-head/#findComment-1475030
Yeah that's what I mean, unplug and plug one at a time. :(
It will be white yes. You can also get an 02 tester. Mechanics have them. You stick them in the radiator inlet when you remove the cap and pump it a few times. If you have a stuffed head, the liquid inside turns to green from blue.
Takes about 10 seconds to check.
https://www.sau.com.au/forums/topic/81163-cracked-head/#findComment-1478296
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
