Steve,
I got my 450x300x76 today no worries. Cheers for that mate, awesome price, should go VERY nicely on the front of my sister's ET !
Get BUYING people ! this is a good deal.
Thanks Haro :P
Let me know if ther is anything else you need.
Cheers,
Steve
  • Replies 161
Ordered my 600x300x76 over the phone just then... can't wait to get it :P Ordered over the phone as my delivery address was different to my billing address and PayPal wanted to be difficult about it :)
Nonetheless, all good now... should get it soon :)
hey mate i'm interested but i don't use pay pal do you guys mind direct deposit?
Hi mate,
Direct deposit is fine. Pm me and I will provide you with our account details.
Regards,
Steve
Just like to confirm delivery of my 600x300x76... thank you JustJap crew :P Very rapid delivery, excellent packaging, and quality service - - - recommend for sure :lol:
Hey Justjap
Where are these FMIC's made from? What material do they use? Bar & Plate?
Also the piping for them $399, what type of piping is it?
Are they all very easy to install into a R33 GTSt?
Thanks
Hi mate, they are made from Alloy and use a bar and plate core.
The piping is also Alloy.
They are relatively straight forward to install if you know what you are doing.
Cheers,
Steve
Cheers,
Steve
hmm cool
dont suppose you know anyone or place to install them cheap? as in good quality/reasomable priced? I might need the fan blades cut and front bar (stock s1) cut also.
Hi, Steve,
As I want performance, not decoration, what do these intercoolers flow like? Can you give flow figures and pressure drop, please?
Am I right in assuming that there is no difference in the kits betwixt SI and SII Skylines? Mine is an SII. I suspect the amount of cutting for the front bar would be different - I think the SII needs less, is that correct?
Very interested in the cooler & pipe kit.
Thanks a bunch. ;)
Hi, Steve,
Thanks a bunch.  :D
Hi mate, thanks for your enquiry
I dont have flow data on these coolers, as they are the same as all the other hybrid style coolers on the market and should handle up to 300rwkw.
To my knowledge, the series 2 bar should require less in the way of trimming than a series 1 bar will.
Let me know if you require any further information or would like to proceed with an order.
Cheers,
Steve
hi, i will be purchasing one of the 450x300x76 with the 2.5 inch inlet/ oultes on Wednesday. any idea when stock is arriving???
Cheers
Hi again, just paid for one of the 450X300X76 coolers with the 2.5 inch inlet/outlets any idea on wait times yet??
Hi Copey thanks for your order
At this stage we are expecting our shipment in approximately 1-2 weeks
If you have any further questions please dont hesitate to ask
Regards,
Steve
Hi guys, the 600 x 300 x 76 and 400 x300 x 76mm intercoolers with 2.5 inch inlet and outlet are now in stock.
Everyone who pre-ordered one of these intercoolers will have their orders dispatched immediately.
Cheers,
Steve
hey dude. i got a r33 gts-t and putting on a gtr front bar and i was wondering which size intercooler would be best. I dont want it hanging out under the front bar or too over-sized with heaps of turbo lag and inefficenience but i also dont want to be dodgy cheap and nasty.
Your probably better of pming me so i dont forget. thanks heaps
Hi mate, a 600 x 300 x 76mm intercooler is the most common size for an R33 GTS-T
Will pm you also with this information
Cheers,
Steve
hey another question. your piping kits for the r33 gts-t, i have the stock plenum chamber so i just wanted to make sure it was designed the standard position not next to the engine with aftermarket plenum chambers. Also i want to keep a plum back bov on for legal reasons so is the piping suitable for a plum back with an entry point or only atmospheric.
Thanks for your help
ow sorry and to add to that atm ive still got the stock exhaust manifold and low mount stock turbo. Will the piping be suitable and when it comes to upgrade will i need to buy new piping to fit a bigger turbo or top mount
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
