hey guys i have a r33 gtst series one n the powerwindow little swichty thigny and the door lockin thingy next to it that controls the passenger side door lockin thing is rooted, i took it all apart n i need a drivers side power window button, you know the one that says Auto, and the lockin door noob thats next to it, i need noobs cuz my one's are rooted
does neone know where i could get them in brisbane/sunnybank :)
any help at all is really greatly apreciated!!
regards akki
https://www.sau.com.au/forums/topic/82271-queenslandr/
As I pm Akkii, belgarion, I had the same prob, and I got quoted $900 for one from nissan, so I decide to pull the sucker apart, in the end it was the relay in the door itself and not the switch, just have to pull the whole door trim of and there would be some homely corrosion waiting for you.
https://www.sau.com.au/forums/topic/82271-queenslandr/#findComment-1492290
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
