Hmm cant any time soon but maybe in a month or two i will go up once i have the car all sorted out i am keen to give the whale a run :P
Leigh
Hey guys i will be going up to wsid today at round 3pm to watch and race, if any one is interested ill meet you up there.
https://www.sau.com.au/forums/topic/82629-wsid/#findComment-1496193
ha ha sorry for short notice but i didnt really know i was going till the last minute.
Car was fine just one miss (coils) i ran on street trim (18" rims)
.8bar and was able to pull a 13.4
next step
camber kit, and 16" x9 rims with slicks
should break the 12.9 hopefull.
I am not to worry about the time as i beat just about every other skyline up there except the bloody GTRs so much grip.
Oh and it sucks driving all the way up for 4 runs to turn around and come home by 12:30
https://www.sau.com.au/forums/topic/82629-wsid/#findComment-1499255
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
