My 98 Stagea is nearing 100,000kms and so looking at replacing the timing belt and water pump as well as a general service.
I have been quoted by a Nissan dealer (in Perth) that to do a basic service (96,000kms service), change the timing belt and water pump would be around $800. Is this too expensive or about right for the work to be done.
I don't have the abilitiy to do the replacement myself, unfortunately.
I assume that I shoudl also get the bearings and seals replaced at the same time (following advice from other threads).
Any assistance would be appreciated.
Cheers, Al
https://www.sau.com.au/forums/topic/82718-timing-belt-replacement/
Hi guys, as previously posted I only replaced the timing belt. There was NOTHING wrong with the water pump or the tensioner or the idler pulleys. There was no seal that needed replacing. I have done 5 Skylines and never replaced a water pump, tensioner, idler pulley.... I just needed to do the cam belt. I still have one that has done 180,000 k's and it still has the original water pump, tensioner idler etc etc
The 100,000 k service is "replace cam belt" not replace water pump, not replace cambelt tensioner. By all means get them to check it, but 99% of the time it won't need replacing.
Thanks SydneyKid
So really it is a case of replace the other parts if they need to be replaced but otherwise there is no real point. I guess the other posts are all thinking replace everything in the one hit since the labour cost is high to pull it apart.
Just going to get the basic service now at 96,000kms and then get the timing belt changed next service and they can check the other items - if they need replacing will do so otherwise leave them.
Cheers, Al
Thanks SydneyKid
Cheers, Al
Having seen what a broken timing belt can do :-( I suspect the other way around would be good.. ie I tend to change them before 100,000k's, not after..
But I agree with Sydneykid, the other stuff virtually never needs changing - so shop around and get a good price for the belt change (I'd guess that somewhere in the $400's would be about right...).
Edit: Just in case you don't have it, I've attached the R34 maintenance handbook - I think it would be a safe assumption to apply the same to the stagea.
Ian
R34_Scheduled_Maintenance_Handbook.pdf
  • 4 weeks later...
My advice .If You change the timing belt always change seals.They cost few bucks and if they start leaking then You have to take everything off ,timing belt as well.Bit big job to replace seals.
If You ask in Japan they always in 99% changed water pump with timing belt.Probably because is a easy job with timing belt ,and if You pull out WP and open/brake then You can see turbine condition .In some cases is good to change specialy in hot areas.Usually are WP changed when they are leaking ,but its not always case to change WP.
And tensioner pully depence how much it cost.If its not expensive up to Yu...
Timing belt manufacturer recomended timing belt change on 80000kms.
Edited by familka gtr
When my old S1 R33 had this done, cost me $1000, but tensioner was stuffed, yes stuffed, did not spin at all, i still have it :( and got the N1 pump for $50 so thought why not, BUT I also had a tune and a full serivce and some other bits and peices done too.
The thing to always keep in mind is that good Japanese mechanics charge like brain surgeons. And bad Japanese mechanics are hopeless and charge like lawyers. The costs of parts is cheap compared to the cost of labour, that's why the Japanese have so much bolt on stuff. It lowers the cost if you have a good mechanic and saves the stuffups if you have a bad one.
That is simply not the case in Australia, so I don't buy parts I don't need just to maybe save on labour later. I don't reckon it's cheaper, because where do you stop? If I change the water pump, then I should change the camshaft oil seals. I should change the cam cover gaskets too. While I have the camshafts out changing the oil seals, I should change the valve stem seals. etc etc
When I change the cambelt I check the other stuff and if its OK, then I just change the cambelt.
:( cheers :)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
