  • Replies 51
i have had 5% tints on my past 4 cars.. one of them had silver too (fully reflective - like mirrors).
It is REALLY difficult to drive at night if its a dark street, just keep that in mind (basically, opening the windows/doors and leaning out or using the mirrors to reverse!)
I can give you a number if you want, he does it on the sly cause its illegal... PM me.
I got my car done at Sol-ace after I bought it in September. I got their 'formula one' (supposedly the world's best tint *pfft*). Not only did it cost me $400, but you can hardly even notice it's there and to make matters worse, have had to take it back to be re-tinted twice due to big bubbles and scratches!
I would have really liked a nice dark reflective tint...
Moral of the story....
Chat to you guys before doing anything to your car! :thumbsup:
boys
there is a guy here in fairfield (sydney) who will do any tint for you except colours ie 5%, 20%, 35%(max legal in NSW ha ha) etc
he has done around 10 of my personal cars and can guarentee his work. he takes his time 2 make sure it is done right the first time!
price eg VT commodore $220 for 20% tint it is good quality and will not bubble i can give u his contact number if u message me
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
