Hey all,
Did a search for this but couldn't exactly find the answers. I just got my AVCR installed into my R33 the other day. They set it up at 7, 9 and 10 psi (off, a and B setting) however on my display i'm not getting any readout from throttle or rpm.
The boost setting reads properly but i'm just wondering if they haven't hooked up the other sensor wires from the AVCR to the computer or if there's some other possibility. Haven't asked them about it yet just thought i'd do some asking around first.
Cheers
nah no display of duty either. They must not have installed it properly. I know they said they had difficulty cause the one i gave em had jap instructions ( i kinda thought they would have had some english ones around )
Anyway i've gotta take it back again so i'll ask about it at the time. thanks man
I installed an AVCR for a friend of mine.
I spliced in to the the relevant wires of the loom and it displays fine.
They have simply installed the avcr and not done a 'complete' job.
How much did they charge?
I had the wiring done in under an hour.
I'm rather impressed how well it works. Slightly better than my Blitz SBC-iD. On a small turbo it has absolutely no issues forcing the turbo to hold what ever boost you dial in.
Most EBC's that are not closed loop (monitor boost levels and adjust duty cycle to obtain the desired boost level) will tend to tail off boost at high rpm. But only when pushing the turbo to its limits.
    • Come to Eastwood, you'll get plenty of that 馃ぃ
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
