Autometer Boost Gauge (gauge measures 65mm from left to right across the outer rim of gauge)
Perfect Condition!!
Black face.
Comes with black holding cup, screws, mounting bracket + holding ring + wires/vacuum hose.
Reads up to 20psi
Will also throw in 2 free additional chrome cups!
As seen below, but my gauge reads in 5psi intervals, so 5, 10, 15 and 20 numbered.
PICS BELOW!!! SCROLL DOWN!
Now off car, have upgraded to a complete set of new Electronic gauges.
Asking $120 or near offer.
Custom ADVAN front strut brace to suit S13 Silvia or 180sx.
polished finish.
SOLD!!!!!!!!!
Autotechnica Steering Wheel - no boss kit.
Black leatherette surround, carbon fibre like grip section, minor scratch on left hand side. Polished centre piece.
2 x red naaaaaaawz like buttons for horn ;);)
Pics by email.
Asking $100 pick up in Sydney
Located South West Sydney
Edited by DORIFTO
https://www.sau.com.au/forums/topic/83207-boost-gaugesteering-wheel/
will give ya $75 for the boost gauge.
if your interested giv me a buz on 0418 537 181 or email [email protected]
Thanks for the offer, however its short of what Id settle for.
Lowest Id go would be $100 pick up/meet up.
PM's replied to.
Boost gauge comes with everything you need to connect, including vacuum hose, wires, black cup + ring and mounting brackets/
AS NEW CONDITION.
Will throw in an additional 2 free chrome cups also.
Edited by DORIFTO
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
