  • Replies 45
ummmmm, yeah........That may be a little difficult. The ***n RTA say they need all the original paperwork to register the car. All this original paperwork was lost by the customs agent when my car arrived......
I cracked the shits in the RTA & told them to call DOTARS in Canberra to sort it out. The RTA people refused & said they needed the paperwork.
I just left the RTA after some more swearing & then I called DOTARS & the guy was like "You should have just got the RTA to call us & we could've sorted it out."......AAAAARRRRGGGGGHHHH
He's gonna send me a certified copy of my Import Approval & then I should be able to register my car.......If not, I'm gonna flip.
https://www.sau.com.au/forums/topic/8342-sat-11th/#findComment-120673
hahahahaaa FAT A$$
$$ BLING $$ BLING $$
geez man it will feel so much better when u get the pulsar on da road davey after all the shit your going through...
ok whats say a 10:30 meet at BK ??? then go to MMMMM together to make a grand entrance ??? i think i might drive my n13 instead of the familia... hehehe not sure yet...
THIS
or THIS ????
https://www.sau.com.au/forums/topic/8342-sat-11th/#findComment-120691
Originally posted by BY BY
Frank: thats a very nice Familia you have there...... why the hell dont you $bling$ it out more often :thumbsup:
im a LAZZY A$$... plus i am up central coast most of the time with the car so thats why im never out WESTSIDE much... though this sat im staying down so it outting time...
they should custom make a BOV just for daves GTiR..
VVVVVVVvrrrrrrrmmmmmmm $$ BLINGGGGGG $$ VVVVVVVRrrrrrmmmm $$ BLINGGGGGG $$
https://www.sau.com.au/forums/topic/8342-sat-11th/#findComment-120719
ROFLMAO!!!!
Frank you funny bastard!!
I thought you sold your N13......
Thanks Tosh & everyone........I may be lucky enough to have it out by this weekend but I'm not counting on it.
I just picked up an AVC-R & SAFC so I now have a hell of alot of power waiting to be installed in my baby.......
https://www.sau.com.au/forums/topic/8342-sat-11th/#findComment-120742
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
