Quick report -
so far done about 220kms, used about 35 litres of the stuff! Shitehouse economy! Maybe the oxygen sensor for the ECU can't tell its got 10% more ethanol in it, much the same of the dyno's...... so its adding a extra 10% to light load cruise?
Knock levels about the same
  • Replies 47
The O2 sensor doesnt know that you've got ethanol in it, but it will detect the leaner mixture and the ECU should compensate somewhat.
Ethanol has a lower calorific value than petrol, so basically the SAFF stuff (or any other ethanol mixed fuel) has less 'bang' or energy for the same amount of petrol. Thats why your economy is suffering, and is one of the major downfalls of ethanol mixed fuels. Usually the economy drop is roughly 2-3% in most cars for a 10% blend. If you're suffering much more than that, then something is wrong...
So IMO the bottom line is that you're not really saving money on ethanol fuels, unless its able to at least compensate on the pump price with respect to the fuel economy loss. That means roughly 5c/L cheaper. I'd have no problems using it in your average 10 year old car I guess, but I dont see the point using it in our cars.
Edited by Busky2k
that's what I thought too busky
Your car will only use more fuel in closed loop ie cruise/constant speed where the ecu detects leaner condition and add extra fuel. In open loop it won't know which fuel is in there.
The added avantage of this fuel is better knock retardation. So you can run more boost/timing safer. If you want more power you wil have to fill up more frequently :D It's part of the game unfortunately.
Well over all, I got 370kms out of a tank. The last hundred odd kms was just off boost driving around really.
Economy wise it went pretty close to what I usually get out of a tank of BP/Mobil, maybe 30kms less
I'd say overall, its not any better in regards to performance, knock levels where pertty similar.
I guess the jury is still out, need to do a bakc to back dyno to see if its any better
But, from what I experienced, if you where stuck, and needed to fill up, it would do the job pretty well
Hmmm. The only issue I have in terms of 'knock retardation' etc is that if the petrol is rated at 98 RON, is it tested including the ethanol? If 2 fuels are 98 RON rated, and one is ethanol blend, then neither should have advantage over the other.
SAFF would theoretically allow MORE timing if they start with a 98 RON base and add ethanol, rather than a 96 RON base and then adding the ethanol to make up to 98 RON. (Ethanol has an octane rating of ~110) Might be worth firing off an email to SAFF to see which option they take to make their 98 stuff.
Edited by Busky2k
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
