Hi All,
Im currently rebuilding my R33 RB25 engine.....
I was asked by the guy doing the boring of my block and recondition of my head if i would like to get it balanced....
My uncle who has worked for nissan for many years and is rebuilding my engine said its not really necessary....
Being a girl and not knowing much about rebuilding engines, i thought a balance was something to do with the engine and the new parts going in it.....but i learnt it was to do with the pressure plate, flywheel and crank.....
As for the parts im only getting forged pistons, a metal head gasket, race bearings, a heavy duty clutch.....and everything else necessary for putting it back together as that is costing my around the $3500 mark and i really dont have the finances for even that....
To the people that had have experience in rebuilding enigines.....
IS IT REALLY NECESSARY TO HAVE IT BALANCED????
Thanks..............
liz :angry:
https://www.sau.com.au/forums/topic/84247-rebuilding-rb25balancing/
Liz, having been down this path and done some engine rebuilding in my time and worked as a mechanic for a long time so I'd suggest:
dump the metal gasket and use a stock one, $80
get the block O ringed (a stainless ring about 0.6mm around each cylinder for the stock gasket) (around $120) $200 has to be less than the metal gasket which retail about 400
modify the oil system at the top face of the block. Close off the front feed of the 2 along the block. Sorry no pics but there is one for the VCT and 2 for the head oiling. Helps prevent over-oiling the head and lack of oil in the sump, hence oil surge if cornering hard. These are just standard inserts.
Straighten the crank, remove the oil plugs and tap and fully clean the galleries. Insert grub screws.
Balance from harmonic balancer to clutch. This will make it run and feel much smoother and is good for longevity of the engine and smooth power delivery if pushing hard (eg track)
Pull all welsh plugs and oil plugs. Acid dip block and fully clean ready for build after fitting pistons.($70)
ACL heat treated race bearings around $140 using RB30 mains and SR20 Big Ends (unless you can now get specific RB25/26 sets)
Use GTR rods(about $250), get them x rayed for integrity($30)
I had all this done and a few other things for around $1200 with a recommended reco shop in Melb, but I had no previous business there.
Hi....
Thanks for your response.....
I already have all the parts i need and the block and head are almost complete.
I got all my parts, the boring and headservice for just about cost as i know a friend that is a manager of our local repco.
I think i will get it balanced for a smoother delievery....i do like to take my car for a test and tune now and then but not as keen on the track yet.
Thanks!!!
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
