  • Replies 127
Posted Images
PM me your number, I'll sms you the address mate...
Mr Ed32, not it never ends :)
Have you installed the front splits and rear speakers yet? Cause the speakers i bought is still sitting in my boot and i don't have a clue how to remove the rear speakers.
Cheers Mate
Hey mate,
To install the rear speakers, you need to do the following:
1) Remove rear seat completely
2) Remove one side of the internal trims
3) Remove rear parcel shelf
4) Remove the child harness brackets
5) Remove rear speakers
6) Refit everything...
Sounds simple right? Took us a good few hours :)
I've been really busy lately, will try to get that write up on my site soon ~ sorry about the wait. Hope this helps!
Just don't be lazy and force the parcel shelf, quite fragile i think...
Trust me d00dz, R34 is totally different.... just don't know where to look let alone apply a screwdriver to :D
thats so true. I've practically birded the bolt on the child harness so i thought fk it... I tried the front speakers and un done the screws etc on the doors but wouldn't lift off.....kinda gave up by now...but thanks heaps for the help stan...
BTW did you end up fixing up the problem with your fuel consumption with the o2 sensor....cause my fuel consumption is fkd up....i probably get around 300-350 per tank...
thanks for the help anyway
Cheers
Mark
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
