  • Replies 148
I like to rate girls on how many beers it would take before you'd root them.
1 beer means she pretty hot and you don't need much encouragement
10 beers means she's fugly and you'd rather sleep with the dog
1 carton means you'd rather wake up in vomit than next to her.
See'ya:burnout:
P.S. This doesn't work if your like 25GTT and root anything that walks, as I heard the rumor.
https://www.sau.com.au/forums/topic/8459-motorvation/page/7/#findComment-127654
YEah yeah everyone bitch about me at night when I don't have net access huh! Ok well now i know whilst at motorvation to be on the hunt for a guy wearing a pink carnation :uh-huh: :lol:
No, I am a bit particular in girls...:P so c'mon spill the rumours! :-)
Cheers for the comments skyzer! good to know someones got my back :)
https://www.sau.com.au/forums/topic/8459-motorvation/page/7/#findComment-128583
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
