hey guys i want to upgrade the ecu on my r32 gtst but i dont wana spend the 1500 odd on a power fc AP Engineered one stuff that.
but i think i might go 4 a Greddy emanage am i better of getting just the standard blue emanage with the extra harnesses or the emanage ultimate.
im not going to go hardcore on mods ive herd that the emanage can support up2 300kw, i want be going near that 250 max is my goal.
things i wana do
Intercooler --Hybrid Gt Spec
Split Front and Dump Pipe -- BATMBL one (already have cat back)
Cams--- HKS or GREDDY ??? which is better??
Turbo --- HKS GTRS KIT
Fuel Pump--- TOMEI?? ive herd WALBRO arnt that good> any ideas which 1>?
Z32 AFM
ECU --EMANAGE
EBC-- PRofect B
Injectors-- GTR?? will they flow enough??
that seems about it what do you guys reckon will the emanage b ok 4 that??
thanks heaps simon.
https://www.sau.com.au/forums/topic/84905-rb20-emanage-or-em-ultimate/
This will no doubt change your plans.
http://www.skylinesaustralia.com/forums/in...showtopic=81906
RB20DET AP PFC $1040 delivered.
There's no real need for a hand controller, if it knocks it flashes your dash light, you then know to get it checked out and find out exactly why it is knocking.
* The PowerFC runs the rb20det's really nice, like factory if not better, strange enough it felt smoother through acceleration. The stock ECU I had a little bit of an iffy slightly hunting idle, the pfc has got rid of that idle.
* The PFC boost control kit works well, an AVCR would be nicer as it allows rpm and gear boost control (Good to aid traction in lower gears). The AVCR being a closed loop boost controller monitors boost level and adjusts the duty cycle in real time to achieve the boost level you have set.
This helps prevent the horrid boost drop/tailing off at high rpm when running a turbo near its limits.
* Tomei and HKS cams are known to work well. I prefer Tomei.
* Fuel pump - Bosch 044, mount it internally. If done correctly they are quiet.
* Z32 afm will work fine.
* GTR Injectors will be fine, but do remember that you will be up for the cost ($250-$300) + cleaning ($150 + resistor pack ($100 S/H - $190 New)
Edited by Cubes
hmm interesting i would touch the h/c anyway could end up in a big bang! but want my installer/tuner need one?? beening a ap engeneering one they want have one more than likely yeah?? hmm but just curious about the emange still how will that go?
thank simon
thank simon
The EManage is a piggy back solution, there is no comparison to a Power FC (FC =Full Computer). I wouldn't bother with an EManage on an R32, if I only wanted to spend $700, then I would get the R32 ECU chipped and tuned live on the dyno.
:D cheers ;)
All the reputable places I talked to about tuning an AP Engineering PFC said that they don't need the hand controller, and that using a laptop and the software they have allows for better tuning anyway. So I wouldn't bother with it if you're not gonna touch it yourself, cause they don't wanna touch it either :D
The group buy is $1040 delivered to your door.
It should be closed, the closing date is the 26th of august.
No doubt it will extend due to lack of interest?
Slap the link in your sig and become a post whore, a lot of ppls don't look in the group buy section. :D
If you buy through greenline or the likes there is a chance you will get done for GST.
Edited by Cubes
Emanage would work well with an auto setup.
nice 3000-3500rpm stall convertor with a tricked up auto would launch damn hard, nice street weapon. :D
Thats when the rb20det box gives way and your left thinking about spending $1500 on an rb25 gearbox + $800 worth of clutch (not inc. labour). For the same money you can get a nice auto setup, depends what you want the car for.
I've considered an auto as its a daily driver and I enjoy small squirts fromt he traffic lights up to the speed limit but I have my heart set on the local track. :P
you say about that fuel pump my pump now is rather loud on start up like a whining noise whilst turned to on u can hear it until it ahhh loads some fuel in the system
is that normal or is it shagged neways??
All fuel pumps have a nice little buz.
When the bosch pumps are mounted badly they tend to vibrate and create a surge grrrrrrrrrrr bad really lound annoying noise.
Mine is mounted externally and makes the horrible noise on hot days.
As said the horrible noise isn't the usual bzzzzzz, its the grrrrrr rrr r r r rrrr rr :D
ahh ok is it easy to install/mount them properly yourself??
do i have to get that 044 one or can i get the 040 because its a bit cheaper?? will it do the job ok?
Do it your self and it will get done right. :P
I know Shaun @ Boostworx does a good job that doesn't make any noise, he's in sa though. :D
There's a DIY guide how to mount a bosch pump intank in the guide section, predator I think did the guide.
040 will do the job BUT they don't mount as low down in to the tank. Grab what suits your needs.
A GTR pump may very well supply enough fuel. Chances are it will.
hmm what suits my needs... so the o44sits lower meaning it will be less noisy? sky180 sells them and it says the are "recommendly" installed exteraly
is this right or wrong so i should be able to do it ok thou hopefully bcoz everything i install in my car seems to be a mission.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
