plex 15th
  • Replies 261
Guest KILLER-T
I was playing around with the timing last wednesday night at the plex i dont want to play around with too many things at once knowing my luck if i gave the timing a few more deg advance and then cranked the boost up my engine would blow up half way down the strip my G/F would kill me she is still going off at me over the last rebuild:argue:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/13/#findComment-138144
Originally posted by macka
what u laughin at.......?
13.4 @105 is hardly anywhere near 12.9 @113
hey ya fat bastard, your memory aint so good these days. I've pulled a 13.105 @ 108 mph, which puts me a whole 0.107 behind you..!!
if I farted during the run I'd beat your 12.98. be afraid fatboy.
https://www.sau.com.au/forums/topic/8519-plex-15th/page/13/#findComment-138202
Osc@r, I think Macka was having a go at me and rev, with our stock snails, we haven't yet put our snails on steroids, yet.
Macka, what was the best time you ran before you changed your turbo? I didn't think we would have been able to push so deep into the 13's with the stock turbo, but it looks like the 'plex is providing some good times.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/13/#findComment-138206
Sorry I thought you both had them, then Macka really should be doing much better than you?
17psi? What boost do you currently run it at, or is it hard to tell with your bleeder/spike valve?
When is your EBC getting here, can't wait to see you beat Macka, then he'll have to wind his boost up.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/13/#findComment-138730
I wasnt talking to you A-hole
stock turbo cars as Paul says..
Go back to your silvia club where u belong!
https://www.sau.com.au/forums/topic/8519-plex-15th/page/13/#findComment-138969
See'ya:burnout:
Hes gotta run 17psi to even come close!
Hey Paul u battin for the other team? haha
could take that a couple of ways..
https://www.sau.com.au/forums/topic/8519-plex-15th/page/13/#findComment-138994
Works, Good luck, let me know when your going down to the plex, I'll come to see if you improve your times.
Macka, I'm not batting for the other side, just promoting some friendly rivalry, you know I love you the most.
See'ya:burnout:
Thats ok then.....
https://www.sau.com.au/forums/topic/8519-plex-15th/page/13/#findComment-139039
I've had a play with the s-afc II and it seems pretty easy to tune. Without a dyno I have already tuned in some fat-ass power across the rev range, used up a bit of fuel tho'. Richen the bottom end and lean the top end and bingo! The mid range is a little tricky
I am quite amazed at the amount of sting the s-afc gets out of the stock motor.
I think I'll aim for another 0.4 sec improvement, without toluene, on the good ol' 205's and 10psi.
https://www.sau.com.au/forums/topic/8519-plex-15th/page/13/#findComment-139149
rev, let us know when the car will debut with the S-AFCII, I'm sure a 13 flat would be impressive on the stock turbo. How can you monitor the A/F ratio of you car for tuning? or do you adjust the fuel and see if you increase the power?
Good luck for the 0.4sec improvement.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/13/#findComment-139286
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
