After talking to Garage-13 I wanted to know, how many people would be interested a 260rs bodykit. B)
I have some prices for you - (these are if we can get 5 people interested in the part)
260rs Front Bar :D $420
260rs Rear Bar :) $400
260rs Side Skirts :) $220
Post any comments or suggestions here :D
Do you think that is a fair price? :huh:
*UPDATE*
Im getting more quotes from different places. Post up your bodykit suggestions.
Edited by Stagea RS-Four
What about the wing? I already have one but just for other peoples sake can you get a price on those?
Also, are there series 2 versions available for those of us with NEO power :huh:
I'm hopeing to get some interest in the front bar as well. Thats the part I'm after. :D But for this group buy to work (in regards to the wing) we need to get at least 5 interested. Then we come to the exciting delema of loaning a genuine wing to base the mould on. If you can help with this, please post here. :huh:
The wing for sure!! :huh:
I think thats the only thing my car needs, as l like its current kit.
Where as we move to something plain...such as mine <_< lol, I like your Stag very much NRGIZD. Very nice :D
260rs Front Bar  :)  $420
Post any comments or suggestions here :)
Do you think that is a fair price? :)
*UPDATE*
hey mate im after side skirts, do u have any good pics of the 260rs ones close up ?
dont want em too chunky and outrageous :D
ta
Brad
Who on here owns a 260rs? Could you please take some pics of the front bar, side skirts and rear bar?
Anyone have any idea how we would go about getting the Genuine kit ofr the moulds?
I can get someone to mould them for us.
Not sure on prices but he is a good mate
www.topstage.com
Can get CF, FRP, Plastic, whatever we want... i prefer plastic (doesnt crack/break in crashes/bottomings out)
Could you get some quotes for us lad? :)
  • 1 month later...
Yes, we just need the part to mould... i cant really quote anything until there is a front bar for moulding, so someone would have to buy the kit first and then we could go ahead and get quote
I gaurentee though, that the price wouldnt be high or anything.
Ill try and speak with freddy early next week (i start uni then, and he is close to uni.. soo ill see)
Gotta speak about bonnets too
Ok,
I went today. Currently there is a shortage of CF (he buys from japan) and he will have a batch in soon. The prices i asked for are as follows
Fibreglass bonnet, OEM - $550-600
Fibreglass structure, CF top layers, OEM - ~$750
Id like everyone who wants one to speak up, because if we go ahead, i would have to leave my bonnet with him for ~4 days to make the mould, so i am not going to do that for only a couple of people (i drive a lot, couldnt loose car for too long unless its a must)
The body kits i will send him pictures of and he will quote from there, i just hope the front bar is a single peice, makes things a lot cheaper.
Naturally, the more people we get interested, the cheaper and cheaper everything gets.
I test fitted a R33 GTST sideskirt, and it fit no problems. Infact, was a TINY bit too long. Just make sure the rear door can open.
Once i get prices for the front/side/back, we could all probably chip in for the kit from japan and then just get it replicated. Also, are the prices from Alex (G13) from yahoo japan? Or is it a plastic kit like std?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
