When I hit 4,500RPM (which is probably when I'm hitting full boost) in the gts-t R33 skyline, it starts to make a squeeling noise and does it in all gears when hitting 4,500RPM. Anything under 4,500RPM, it doesn't make that noise.
It's pretty much a stock standard skyline (apart from the exhaust from the cat back, turbo timer & boost guage). It's done 120,000k's and I just did a oil filter & oil change to it on the wknd plus radiator fluid but was making this noise before I did the service.
Just wondering as to what it might actually be?
Someone has said it could be one of the belts that are making that noise.
Another person has said it's the bearings in the turbo (dont know about that one).
Any ideas or anyone know anythin from this happening to them?
It's a 1993 model.
Thanks!
Edited by r33skyliner
https://www.sau.com.au/forums/topic/85946-squealing-noise-when-hitting-4500rpm/
Sounds like belts, free rev and bounce it up to 4,500 RPM (don't hold it up there), and see it makes the noise.
It's highly unlikely it's your turbo, turbine speed is dependant on engine load NOT RPM, so being out of gear will take the turbo out of the equation.
If it does then spray some WD40/RP7 on the belt pulleys, do it one belt at a time, if the noise goes away you know which belt it is. Then proceed to tighten that belt.
I hit about 5,500RPM last night on cold start when I first started the car and their was no squealing noise in first gear. Hit 2nd gear and still no squealing noise. I then pulled over for about 2mins and then took off and hit 5,000RPM and then it squealed.
So what could this possibly be then? A belt or the turbo or possibly the manifold?
If it is the manifold and a new one is needed? How much am I looking at for one?
I've read the PM's but after diagnoising the problem a bit last night, thought people may be able to further help as to what it could be.
Also to note. When the car was idling last night at lights and in the drive way. The oil guage was sitting between the bottom line and the quater line. When driving, it would then rise up a bit just past the quater line but doesn't go past the half way line.
You really shouldn't be taking it above 2500/3000 until it hits operating temp you know, be nice to your car until it's warmed up, then punish it like it deserves! :P
Did you try it free revving? Make sure it's warmed up, do it when you get home from work or whatever, just AFTER a drive when everything is warm.
If you can get someone else to sit in the car and rev it, then pop the bonnet, and that way if it makes the noise you'll hear it better and might get an idea where it's coming from.
That's pretty low, before you do anything else check your oil level, and what type and viscousity oil are you using?
Just as a comparision, when starting cold my gauge sits at half-way, or 4 as it's marked on the gauge, once warm the car idles at one quarter (2), and when under load climbs back up to half-way (4) and a bit more when going hard (say ~5).
That's a 10w40 yeah? You should be getting better oil pressure than that I'd think, double check your oil level (HOT), just cause it isn't leaking doesn't mean it's not burning it or there wasn't enough in there in the first place.
Sounds like this is just goin to be a costly issue to have it looked at.
Sounds like I rather just give the machanics the go ahead to fix whatever it is. Would cost the same to have it fixed then to have someone look at it.
But, knowing 99% of the machanics these days. They'll say its one thing just to get the extra few $$'s out of you when really it was something little and simple that would of cost me alot less to have fixed.
You need to do what you're most comfortable with, if you've got the time and can keep coming back here for free non-professional help, and the confidence in your own abilities then great.
If you just want it working and are prepared to pay what you will for it then take it to a mech. Have a poke around Qld sub-forum and I'm sure you'll get on to a reputable place that know their way around RB's.
Ok. Had someone professionally look at it last night and they've determined for me that it is actually the turbo. It's the propellar fans (i think thats what they are called) inside the turbo which are actually hitting up against the wall.
This now explains the noise as well as the great lost of power that it once had.
So, I'm up for a rebuild of the turbo.
All up, the rebuild of the turbo is going to cost me a bit under $2g which they'll high flow the turbo for me giving me more power.
So, the car will be booked in to have all this done within the next few weeks and I should be back on the road after thats all done.
I can still drive the car, but highly recommended not to hit high boost as it'll just cause more problems
newho, back to the original noise, even though it has been diagnosed, that kinda noise is generally an exhaust leak of some kind, another hint is that it only happens when you come onto boost or are at full bost
:huh:
nothing to do with the turbo its a leaking exhaust and/or a cracked exhaust manifold . had same problem
It's been determined that it's actually the turbo by 3 mechanic's now.
There inpropella fan is rubbing up against the housing. I'm able to pull that inpropella fan back and forward about 1mil, maybe less which is not good at all. All 3 of stated that it would be ok if you can go side to side about 1mil or less, but not back and forward.
It is a ballbearing turbo.
Car has been booked in with Hardcore Racing to have the turbo rebuilt and high flowed.
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
