When I hit 4,500RPM (which is probably when I'm hitting full boost) in the gts-t R33 skyline, it starts to make a squeeling noise and does it in all gears when hitting 4,500RPM. Anything under 4,500RPM, it doesn't make that noise.
It's pretty much a stock standard skyline (apart from the exhaust from the cat back, turbo timer & boost guage). It's done 120,000k's and I just did a oil filter & oil change to it on the wknd plus radiator fluid but was making this noise before I did the service.
Just wondering as to what it might actually be?
Someone has said it could be one of the belts that are making that noise.
Another person has said it's the bearings in the turbo (dont know about that one).
Any ideas or anyone know anythin from this happening to them?
It's a 1993 model.
Thanks!
Edited by r33skyliner
https://www.sau.com.au/forums/topic/85946-squealing-noise-when-hitting-4500rpm/
Sounds like belts, free rev and bounce it up to 4,500 RPM (don't hold it up there), and see it makes the noise.
It's highly unlikely it's your turbo, turbine speed is dependant on engine load NOT RPM, so being out of gear will take the turbo out of the equation.
If it does then spray some WD40/RP7 on the belt pulleys, do it one belt at a time, if the noise goes away you know which belt it is. Then proceed to tighten that belt.
I hit about 5,500RPM last night on cold start when I first started the car and their was no squealing noise in first gear. Hit 2nd gear and still no squealing noise. I then pulled over for about 2mins and then took off and hit 5,000RPM and then it squealed.
So what could this possibly be then? A belt or the turbo or possibly the manifold?
If it is the manifold and a new one is needed? How much am I looking at for one?
I've read the PM's but after diagnoising the problem a bit last night, thought people may be able to further help as to what it could be.
Also to note. When the car was idling last night at lights and in the drive way. The oil guage was sitting between the bottom line and the quater line. When driving, it would then rise up a bit just past the quater line but doesn't go past the half way line.
You really shouldn't be taking it above 2500/3000 until it hits operating temp you know, be nice to your car until it's warmed up, then punish it like it deserves! :P
Did you try it free revving? Make sure it's warmed up, do it when you get home from work or whatever, just AFTER a drive when everything is warm.
If you can get someone else to sit in the car and rev it, then pop the bonnet, and that way if it makes the noise you'll hear it better and might get an idea where it's coming from.
That's pretty low, before you do anything else check your oil level, and what type and viscousity oil are you using?
Just as a comparision, when starting cold my gauge sits at half-way, or 4 as it's marked on the gauge, once warm the car idles at one quarter (2), and when under load climbs back up to half-way (4) and a bit more when going hard (say ~5).
That's a 10w40 yeah? You should be getting better oil pressure than that I'd think, double check your oil level (HOT), just cause it isn't leaking doesn't mean it's not burning it or there wasn't enough in there in the first place.
Sounds like this is just goin to be a costly issue to have it looked at.
Sounds like I rather just give the machanics the go ahead to fix whatever it is. Would cost the same to have it fixed then to have someone look at it.
But, knowing 99% of the machanics these days. They'll say its one thing just to get the extra few $$'s out of you when really it was something little and simple that would of cost me alot less to have fixed.
You need to do what you're most comfortable with, if you've got the time and can keep coming back here for free non-professional help, and the confidence in your own abilities then great.
If you just want it working and are prepared to pay what you will for it then take it to a mech. Have a poke around Qld sub-forum and I'm sure you'll get on to a reputable place that know their way around RB's.
Ok. Had someone professionally look at it last night and they've determined for me that it is actually the turbo. It's the propellar fans (i think thats what they are called) inside the turbo which are actually hitting up against the wall.
This now explains the noise as well as the great lost of power that it once had.
So, I'm up for a rebuild of the turbo.
All up, the rebuild of the turbo is going to cost me a bit under $2g which they'll high flow the turbo for me giving me more power.
So, the car will be booked in to have all this done within the next few weeks and I should be back on the road after thats all done.
I can still drive the car, but highly recommended not to hit high boost as it'll just cause more problems
newho, back to the original noise, even though it has been diagnosed, that kinda noise is generally an exhaust leak of some kind, another hint is that it only happens when you come onto boost or are at full bost
:huh:
nothing to do with the turbo its a leaking exhaust and/or a cracked exhaust manifold . had same problem
It's been determined that it's actually the turbo by 3 mechanic's now.
There inpropella fan is rubbing up against the housing. I'm able to pull that inpropella fan back and forward about 1mil, maybe less which is not good at all. All 3 of stated that it would be ok if you can go side to side about 1mil or less, but not back and forward.
It is a ballbearing turbo.
Car has been booked in with Hardcore Racing to have the turbo rebuilt and high flowed.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
