Hi guys,
I bought a loom + ECU which was from an R32 but was on an RB25DET.
I was told this was an R32 RB20DET ECU and loom, which is what I need for my RB25DE head on my RB30E bottom end, for my RB30DET.
I am somewhat worried that it is in fact an R33 RB25DET loom, and ECU, and thus is not chippable, and will not be appropriate for the sensors on the RB25DE head, and the injectors, etc.
The serial number is: 23710-21U01
Only hit I could find on that was this guys post who says it is an RB25DET ECU (R33) http://64.233.187.104/search?q=cache:FmHd5...710-21U01&hl=en
I have taken some photos:
I was originally posting this to ask which one was the consult port, but now Im concerned this isnt an R32 ECU at all!!
http://www.grid.co.jp/en/prod/prod93.htm
It seems this is a chipped R33 ECU, that has had a daughterboard installed, and a reprogrammed R33 chip.
This will not be compatible with the sensors on my R32 RB25DE now will it. :)
Hmm. Anyone interested in swapping an R32 ECU and loom for an R33 ECU and loom? The R33 loom would be easier if you are planning on using a PowerFC since the R33 PowerFC is substantially cheaper. :)
Looks definitely R33.. no standard replaceable chip there that I can see.
The ERPOM on the R32 are lot smaller and skinnier..
Actually.. I just pulled out R33 ECU I had lying around.. same part number .. Its a series1 ECU for R33.. sorry bud
That ecu wont fit an r33, the brackets are wrong. The brackets are for an r32.
But the internals dont match what i found inside my r32 ecu either and the part number is slightly different. could it be an rb25de ecu?
got picks of the loom? Thats pretty easy to confirm r32 or 33 from the under dash plugs.
Edited by BHDave
its interesting as it has the top chip socketed.. whereas most of the standard R33 ones don't..
Maybe it is possible to chip them, its just quite expensive?? (that programmer on g-grid site was up around $1000).
Can you see what looks like home solder jobs around the top socket there at all?
Not that I can see. It looks well done.
From what I understand there is nothing inherently different about chipping an R33 ECU compared to an R32 ECU, other than that you need to do a little bit of soldering on the R33 ECU, and that the chips suitable for the R33 are write-once only.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
