whens the next cruise on???
  • Replies 62
Originally posted by | hype^ |
XrSiSt  - come out with me and onarun this fri... i dont know exactly what we;re doin.. but we'll see..
DAMAN>> we'll let u know .. or just ask onarun if ur next door...
SUM1 WOULD LEND U A 'LINE?? damn! must be close!
Hype - I got stuff planned on friday night :whip: but i'll see if I can get out of it. If i go, i'll give ONARUN a call.
Hello!
I'm for a cruise no matter what...May have a 180SX tagging along too.
Bells Line of Road. The Jist is.....
We meet up at a central location. I've always been a fan of Homebush 6C.
From there we could skip accross town to the M2, via Five Dock, before the M2 we could stop at the Space Station McDonalds to pick up any Northerners and Food/Fuel.
Proceed up the M2, throught Winsdor...Need to make sure your tanks are full of the good fuel when we leave Winsdor (Couldn't find a Premium Fuel at Winsdor last time)
Anyway...Leave Winsdor through Richmnond and onto the Bells Line of Road...I know of one or two speed cameras on there at the beginning and cops do patrol (no more then average-like your in the mountains)...It not as oscolated as the Old Pac Road...But there will be some chances for dashes and its quite twisty and interesting to drive on.
One we have reached Lithgow, Coffee, Food what ever.
After that we can either backtrack or go back home using the M4. At which point we'll end up at Homebush...Everyone should (I hope) now where they are when your on the M4.
This is an idea, but I'm open to others.
Guest | hype^ |
that sounds like a good plan.. :uh-huh:
only 2 thing probs,, iv got nfi where this meeting place is..
and i might have to go to sum1s b-day party.. :P
ill try and get out of it....
no matter what ill give ya a call george..
im definatly out if it rains.. (lol still getting used to the car :D )
so how many cars are comming>??
Guest Da_Man
Well the weather looks great so it looks like its on for tonight!!
I'll call George at 6ish and meet up then we will meet up at 6c parking lot at home bush if any questions call me 0414 867 446 Peter or George number above. (Can't add his number due to privacy act :lol: )
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
