GTR NUTZ: please dont tell me you are driving around, in a GTR no less, with absolutely no insurance....
Im not too proud of it, but yes... its only a sunday car right now... that is untill get insurance and 300+KW at all four.
At the moment im mixing around with my parents "spare" car and the GTR.
i hope for your sake that you dont hit a ferrari/mercedes etc....you're finished if you do, sunday car or not.
or that you have a ridiculous amount of money that you can happily give to the person you hit to pay for their car
Its a very grey area this one. I have heard of many stories where insurance companies have failed to pay out claims or reduce the amount they pay because the vehicle was over the power to weight ratio.
But on the other hand if you read the insurance fine print it will tell you that the car MUST be in road worthy condition and I dont think every skyline on the road is roadworthy. By saying that i mean some of us have cars that are too low or modified beyond the Australian Design Requirements. So therefore you wouldnt be covered to the full extent of your policy if they investigated right into it. Insurance companies have still payed the claim in several of these cases before and the still have the legal right not to.
I drove a 250rwkw R33 when i was on my P Plates and I was insured. I know alot of other P Plate drivers do the same, but I think you should be pretty sweet.
The main thing you have to worry about is making sure you tell your insurance company about EVERY single modification you do to the car. My mates car got stolen and the insurance claim didnt get paid because he didnt tell them about the 19inch wheels he had on his car because he thought he would try and save some money by not having to pay as much for his insurance policy. The insurance companies response was that the 19inch wheels made the car more attractive to theives and thats why they stole the car. Right or wrong the can legally back out of the Insurance Policy.
if the car was stolen, and never recovered, why the hell did he tell them it had 19's on it? if he didnt want to put them on his policy, he obviously didnt expect that he get more money in the event of a pay out to compensate for the wheels...
so if the car was gone, the only way the insurance company would know about the wheels is if he told them....what an odd thing to do
i think his plan was for the car never to be stolen or damaged :rofl:
obviously. but he said the wheels weren't listed on the policy, therefore how the hell did the insurance company know about the wheels if it was stolen and not recovered
Edited by madwob
dunno.. but im sure when he told the police it was missing he told them it had 19's.
well there you go...ya lie to the insurance company to save maybe a couple hundred dollars, and it costs you $15-20k.
Because the car was found 2 days later torched and it still had what remained of the wheels left on the car. The wreck was towed to the insurance holding yard and the car evaluated and it was then found that the car had been fitted with items not listed on the insurance policy
its not your mates fault the crims decided to slap a set of 19's on it before they burnt it....lol
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
