Hey guys, im after some 18x8 - 8.5 and 18x9 - 9.5 deep dish rims to suit r33gtst.
can anyone here help ?
tyres getting really low, dont wanna unnesesarily fork out $$$ for tyres when i dont need to
https://www.sau.com.au/forums/topic/87047-wtd-18-inch-deep-dish-rims/
ssr gartmaeirs
18 by 9, +13
18 by 10.5 -6
5x 114.3mm
$2500
Will they even fit on a r33 gtst without rubbing and clearing the gaurds properly???
I am after anything really, that looks nice, doesnt have to be dished, but would prefer it. Just depends on the style of rim i guess.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
