OHIO USA
rb26dett w/manual tranny ecu, harness and more, complete swap w 40-50k miles never installed
WILL TRADE FOR RB25det or mods for an rb25
tein coilovers ha $650 shipped
greddy fmic with piping for rb26dett used 15k miles $500 shipped
greddy td05 turbo kit used 34k miles i never installed them bought them used $2000 shipped
sparco milano black seats with brackets $600 shipped
hks ssq bov $400 new
email me at [email protected]
need rb25 the rb26 is too much for my 240...
let me know
thanks
Edited by sarver
https://www.sau.com.au/forums/topic/87678-fsft-rb26-and-more/
OHIO USA Interested in the seats , pics please.
Thanx
let me know
thanks
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
