hey all
I am new to this forum so i am saying g'day.
i am also a member of ns.com cos i had a 180sx last year.
I have been on a working holiday and now i am on the gold coast going through the process of buying a skyline now.
cheers dave
Welcome to SAU davo32
One question for ya, WHY THE GOLD COAST????
Cheers B
https://www.sau.com.au/forums/topic/87808-new-member/#findComment-1585245
Cheers B
hey grandmasterb.
i am on the gold coast cos i am staying with my mates so there are 3 of us all mechanics looking for a car with me. i have found a car i will probably buy tomorrow. it is up on the top price rang for it but it is in very good order.
cheers dave
https://www.sau.com.au/forums/topic/87808-new-member/#findComment-1586210
hey grandmasterb.
cheers dave
well let us know how it goes champ and when you get it then post up some pics of the beast ;)
Cheers B
https://www.sau.com.au/forums/topic/87808-new-member/#findComment-1591965
i will post picks of it when i get to tassie. i drove from the gold coast to sydney yesterday. 760km with 3 stops each about 10mins at the most.
cheers dave
DAMN thats a bit of a drive there mate.
Look forward to seeing the car and if you need a hand with it at all then give me a holla...
Cheers B
https://www.sau.com.au/forums/topic/87808-new-member/#findComment-1598458
Hi Dave, Todd here (Had the Red MR2).. I just got an R32 GTS-t 2 Door! Are you moving back to Tas. Can't wait to see the new ride!
Todd
hey Todd.
thats what i just bought as well.
i will probably go out to kmart car park for a look on friday night.
is any one else heading out?
cheers dave
https://www.sau.com.au/forums/topic/87808-new-member/#findComment-1600416
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
