Guest DIRTgarage
Yep, that's it. The only thingI would add is that you can get a four point rollbar in place of the six point rollcage which is good to 10.000. For a regularly street driven car this might be a lot easier to get away with.
but must have side intrusion bars fitted (drivers side must be welded in)
You can use a four point welded rollbar if you run 10.999 to 10.000. No side intrusion bar required at all with a rollbar obviously (no way to mount it).
Six point rollcages can have a removable side intrusion bar on the driver's side. No need for any instrusion bar on the passenger side.
Guest DIRTgarage
Kenny, six point cage must have a welded in intrusion bar 4.4.7.1.
four point cages must have side intrusion protection....page 113 fig1 rule book
Edited by DIRTgarage
Old news chap, the recent rule changes (20th August 2004) allow for a removable side intrusion bar. Or else Greg Shultz shouldn't have issued mine with a tech inspection pass on my log book last year!
Removable Intrusion Bars: Effective immediately, the use of removable intrusion bars will be permitted in street registered sedan based vehicles with original, unmodified monocoque construction and full steel roof, running 8.00 seconds (1/4 mile) / 5.00 (1/8 mile) or slower. The intrusion bar/s must be the same diameter and thickness as the main roll cage hoop and must be attached using a minimum of 3/8 inch (10mm) bolts. Male or female clevis attachment permitted. Male clevis must use two minimum 1/8-inch-thick brackets welded to each roll-cage upright; female must use minimum 1/4-inch-thick bracket welded to each roll-cage upright. Bolts must be within 8 inches (200 mm) of the vertical portion of both the forward and main hoops. A half-cup backing device must be welded to the vertical portion of the main hoop (inward side) or the upper end of the swing-out bar (outward side), minimum 1/8 inch (3 mm) extending past the centre of the bolts by the diameter of the tube. Sliding sleeves with minimum 2-inch (50mm) engagement are permitted in lieu of the upper cup. All bolt/pin holes in the swing out bar must have at least one hole diameter of material around the outside of the hole.
My source http://www.dragster.com.au/modules/news/ar...php?storyid=332
Edited by MrBlonde
Guest DIRTgarage
Bloody Shieldsy....he told me the drtivers side must be welded in.....he also said "if you gotta climb over the bastard to get in, you may as well make your passengers too" It works ok and stops you from being lazy and scuffing the sides of the seat getting in and out.
Ahh well too late for me
thanks for the correct info Kenny
see ya on the track soon as you get it all finished
Paul
Paul
Paul,
No problem! You don't need a passenger's side intrusion bar at all either. See you when mine is finished ... finally!
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
