Update...
Item:
T28 from my S1 S14. Holds boost and makes no funny noises but was blowing smoke, mostly on idle so will need oil seals and bearings replaced.
T25g from a 180SX. Same problem as the T28 but has less shaft movment.
Go Fast Bits manual boost controller.
Lost of tyres etc.. Here are the pics..
225 x 50 x 16 Firehawks on Z32 rims
225 x 50 x 16 Firehawks tread
205 x 60 x 16 on R33 look-a-like rims
205 x 60 x 16s tread
225 x 50 x 16 New Michelin and near new Toyo tread
205 x 40 x 17 Federals on WORK equip rims
205 x 40 x 17 Federals tread
215 x 45 x 17 Ventus tread
205 x 50 x 17 Dunlop tread
215 x 45 x 17s tread
225 x 45 x 17 Dunlop and Yokos tread
235 x 45 x 17s Kuhmo 711s tread
235 x 45 x 17s tread
215 x 40 x 17 tread
255 x 40 x 17 tread
18" semi slick tread
Adelaide
Price and Payment Conditions:
Looking for $225 for both turbos and $45 for the GFB MBC. Open to offers on the wheels and tyres...
Contact Details:
PM or email me.. [email protected]
Edited by TUF-200
https://www.sau.com.au/forums/topic/87973-sold/#findComment-1599052
UPDATE
Pair of 225 x 50 x 16 Firehawks on 16 x 7.5" Z32 rims - $150.
Pair of 205 x 60 x 16s on 16 x 7" R33 GTR look-a-like rims. Now painted black with drift only tread - $110.
Matching pair of 215 x 45 x 17 Ventus - $30
Matching pair of 235 x 45 x 17 Kuhmo 711s - On hold for Ben.
Matching pair of 215 x 45 x 17s - $20
Pair of 215 x 45 x 17s - $50
Pair of 225 x 45 x 17 Dunlop and Yokos - $45
235 x 45 x 17 - $25
235 x 45 x 17 - $35
235 x 45 x 17 - $30
215 x 40 x 17 - $15
255 x 40 x 17 - $30
225 x 50 x 16 New Michelin - $70
205 x 50 x 17 Dunlop - $20
18" semi slick - Offer$
The work rims with tyres have been sold. Toyo transpath sold pending payment.
https://www.sau.com.au/forums/topic/87973-sold/#findComment-1611852
Boost controller sold.. Open to offers on the rest. Im willing to trade for other stuff, just post what youve got.
PS: If u have made an offer on anything here via PM and havent heard back from me please PM me again as I may have deleted them by accident during an Inbox cleanup.
https://www.sau.com.au/forums/topic/87973-sold/#findComment-1617351
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
