Update...
Item:
T28 from my S1 S14. Holds boost and makes no funny noises but was blowing smoke, mostly on idle so will need oil seals and bearings replaced.
T25g from a 180SX. Same problem as the T28 but has less shaft movment.
Go Fast Bits manual boost controller.
Lost of tyres etc.. Here are the pics..
225 x 50 x 16 Firehawks on Z32 rims
225 x 50 x 16 Firehawks tread
205 x 60 x 16 on R33 look-a-like rims
205 x 60 x 16s tread
225 x 50 x 16 New Michelin and near new Toyo tread
205 x 40 x 17 Federals on WORK equip rims
205 x 40 x 17 Federals tread
215 x 45 x 17 Ventus tread
205 x 50 x 17 Dunlop tread
215 x 45 x 17s tread
225 x 45 x 17 Dunlop and Yokos tread
235 x 45 x 17s Kuhmo 711s tread
235 x 45 x 17s tread
215 x 40 x 17 tread
255 x 40 x 17 tread
18" semi slick tread
Adelaide
Price and Payment Conditions:
Looking for $225 for both turbos and $45 for the GFB MBC. Open to offers on the wheels and tyres...
Contact Details:
PM or email me.. [email protected]
Edited by TUF-200
https://www.sau.com.au/forums/topic/87973-sold/#findComment-1599052
UPDATE
Pair of 225 x 50 x 16 Firehawks on 16 x 7.5" Z32 rims - $150.
Pair of 205 x 60 x 16s on 16 x 7" R33 GTR look-a-like rims. Now painted black with drift only tread - $110.
Matching pair of 215 x 45 x 17 Ventus - $30
Matching pair of 235 x 45 x 17 Kuhmo 711s - On hold for Ben.
Matching pair of 215 x 45 x 17s - $20
Pair of 215 x 45 x 17s - $50
Pair of 225 x 45 x 17 Dunlop and Yokos - $45
235 x 45 x 17 - $25
235 x 45 x 17 - $35
235 x 45 x 17 - $30
215 x 40 x 17 - $15
255 x 40 x 17 - $30
225 x 50 x 16 New Michelin - $70
205 x 50 x 17 Dunlop - $20
18" semi slick - Offer$
The work rims with tyres have been sold. Toyo transpath sold pending payment.
https://www.sau.com.au/forums/topic/87973-sold/#findComment-1611852
Boost controller sold.. Open to offers on the rest. Im willing to trade for other stuff, just post what youve got.
PS: If u have made an offer on anything here via PM and havent heard back from me please PM me again as I may have deleted them by accident during an Inbox cleanup.
https://www.sau.com.au/forums/topic/87973-sold/#findComment-1617351
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
