anyone got a set of rims Ican borow or buy net to get my car over the pits and they nocked me back because i have 7" rims on front and 8" wide rims on back
i have a compliance to say i can have just about any size wheel on the car but all 4 have to be the same can any one help me out?
Have a set of 16" Stages rims 5/114.3 with as new 225/50R16 fitted.
Canberra based.
Marc2
thanks guys, i had a bit of a debate with the dixon test ofice, aparently the sticker plate on my car say's i can have mached rims but my enginers certificet dosn't, and that is what theay are winging about. i managed to get in contact with the guy who did my certificet and he is going to write me another one. hope he doesent charge me for it seing it was his fault to begin with but well se what hapens.
thanks to every one who ofered and those who pm me, thanks alot it was muchley apreciated
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
