yeah niz im with cam! about the jash thing!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
yeah and cam but if i get a dump pipe to suit right, don't ya think it would make another place for exhaust leakage? that why i was thinkin of sellingmy apexi front and just getting a new dump/front made up!
i agree coilovers are awesome! but i can't justify paying that much unless i was harcore track racer! so i think i just go for the aftermarket shocks and springs!
adrian:p
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
dont really have itme to chase thats why i now use who i do - seems to be very thorough and has the time on his hands to be that way.
I'll get it done just got to find time n money - but first the blow off valve problem - one step at a time - should see the shopping list i have for my car - i mean just even the essentials its huge - need my brake pads replaced soon too or i might end up under a truck!
niz i have a blow off valve that i wanna sell! it's a ssr blow off valve styled like blitz! bit fatter though! apparently very loud (look at me loud) hehe although never put it on my car! if ya want you can take it off me to see if it will fix your problem, if it does you can buy it if ya want, if it doesn't then chuck it back at me in a big tantrum! ;)
adrian :D
Adrian - ok, I get what ur on about now - and i agree.. u should be able to get rid of the Apexi pipe and use the proceeds to get the dump/front combo done?
Niz - understand completely.. thats one thing i hate, chasing people so they can take my $$... fair call..
sorry niz it ain't a re-circulative BOV, it's a atmo-venting BOV :D
but i'll have a talk to a few mates might be able to get you one at a good price i'll see what i can do! why is ur stock BOV playing up or sumfin?
adrian ;)
mines aftermarket - there when i got the car - doesnt make a noise its just leaking air at the moment so its playing havoc with my idling and keeping the revs low so once i get that fixed then i can get it tuned and hopefully it'll be back to its feisty old self - its being sluggish lately and its boring the hell outta me ;)
hmmm wouldnt mind a bit of a ricey loud one. yeah keep your ears out for me anyway - might start looking for one saturday morning because i just want my car back to normal ASAP.
adjust the spring tension on the bov you got at moment? have you tried that? that should stop it leakin! just don't adjust it too much that it's too tight for the pressure to release when your off the throttle! are you going to auto salon niz? cam? if you guys are i'll be there saturday, tell me in advanced adn i'll bring the bov along with me on sat incase your nearby i can drop it off!
adrian ;)
going on Sunday. Hmmm spring tension - me under bonnet equals disaster - would rather be able to blame someone else if anything goes wrong but i may have to have a look anyway if its easy enough. Where abouts are u adrian? arent u thornlie way?
i'm in east cannington i go to thornlie tafe! what type of bov is the one ur using? coz i'm sure if you adjust the spring tension make it just a bit tighter it will stop leaking! coz you haven't upped your boost pressures or anything have ya?
adrian ;)
ahh k.. so the aftermarket one is hanging off the std mount then I take it?
I'm with Adrian - pull it off, clean it and tighten up the spring pressure.. Maybe get your mechanic to do it? Shouldn't take him more than an hour..
i think the boost is up a little more than standard ;) honestly i thought everything was standard apart from the obviousl lowering etc in my car when i bought it - but ive learnt lately that all is not what it seems - it has been played with. So im still learning what exactly is under that bonnet - i assumed that BOV was std til i was recently told otherwise - its nothing ricey looks like fairly standard - havent really taken a close look for myself lately - havent had time might have a look see this weekend see if i can find out make etc
you can do it yourself niz if ya have the right tools!
you probably wouldn't even need to take it off just adjust the spring tension there is normally a lil knob on top of the valve near where the hose from inlet plenum goes if i do remember rightly!
adrian ;)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
