  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Psiker, just whats in my sig to get 13.8.
BPU = turbo back exhasut and k&n pod.
safc is a 1st gen 5 knob one. Also have a 5 puck clutch (stock flywheel) and ran with a fresh set of Yoko A539's at 20psi.
Not much more than shuto and he's run a better time. Need to get back out there now that I'm fmic'd.
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
