  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Neo
I though that C-red did there own compliance? I saw a new silvia that they brought in at another shop? Anyone?
Ken,
can we see you in action at any of the tune days at waneroo?
They only hold compliance for a certain range of cars.
Blue S15's aren't one of them.
Cheers
Ken
Originally posted by GTS-t VSPEC
Neo,
With the new rules then most people won't be able to do the compliancing, only accredited workshops:D
Ken, Sure, another pointless thread can't hurt:D
See'ya:burnout:
Hey if eriktosser can get a thread on freek ( or *****ng whatever) , the Troy has to be worth a little bit of bandwidth.
Cheers
Ken
Ken,
I don't do Wanners pers'e but when the Enjo SES goes there , then I will.
I am hoping the SES Collie circuit and Wellington dam on the 26th -27th April is my next one.
Cheers
ken
Hehe, It's a pity erik didn't show last night, I had a few words of advice for him:D
Why don't you start the thread, you scared?:D
See'ya:burnout:
Advice like
You , your mate , your dog , your horse , your bbq AND your skyline and it's plates , F**CKOFF !!
Cheers
Ken
Ken,
If I'm free I'll try and make it down, will you have the 4WD to toe it by then?
See'ya:burnout:
Yep , I already got it.
Picked it up yesterday.
Gotta love the petrol guzzling maverick/Patrol.
Cheers
ken
